I use ArkMC, which allows me to stream all my media from my laptop to TV without any adapters or cables. Plus, the app is not buggy and very user-friendly, supports wide range of different formats.
If your laptop has a HDMI port just use a HDMI cable to connect it. Unless you are trying to do it wireless in which case you need the data from the laptop to go first to a receiver, then the tv.
Hello. Do not use HDMI for this purpose, instead go to Walmart and get a usb cord that plugs into your tv. Then use the remote control for your TV to push input and locate your computer, usually at the bottom of the list. Regards, Joe
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
