I upgraded my windows 10 pro before three months ago, But now facing black screen error, I don't know more about it. Is there any way to fix Windows 10 black screen error.
SOURCE: I purchase windows xp pro
Yes, you should back up all your Documents and pictures, and all your programs.
I would also recomend you (before you upgrade) you download and install DriverMax (http://hollyecho.com/drivermax.htm) - this will create an archive of all your device drivers - Then put these drivers on a CD or Flash Drive (that way you will not have to hunt for all the drivers for your computer - XP Home and XP Pro uses the same drivers.
Since you are re-installing the operating system anyway - do a secure wipe on your drive, that way any virus you know will be completely gone.
Then just insert your New WinXP pro cd and follow the promts!
SOURCE: get error 568ff5ch
Instead of upgrading, do a full installation of XP. You will be prompted to either keep your old system or remove it. Choose to remove it. That will solve your problem. Don't forget to rate this answer
SOURCE: Black screen and blinking underscore before loading OS
chipset drivers that are loaded onto the harddrive are not the same as the ones in the "new" computer you put it into.
The only way to do that is format the drive and start from vanilla.
This is very common. -Jeff
SOURCE: Frequently get a blue screen with a Fatal Error message.
Try booting the machine up in safe mode. To do this restart the machine and repeatedly tap F8. When the sub menu appears choose safe mode as see if you get the same message again. If you don't and it boots to safe mode let me know asap and i'll take you through certains steps to recover the operating system.
SOURCE: reinstalled windows xp pro and
Software & Driver Downloads - Compaq Presario SR1030NX Desktop PC link @ http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=405451#N152
Click on "Drivers - Audio" & download & install "Realtek AC'97 Audio Driver Update" ~size:(10.96M) to your PC.
Hope it helps.
