SOURCE: LG Dyer blows 30amp fuse frequently
Hello davidkado,
There is a high probability that when you replaced your fuse box to circuit breakers that the wiring at the fuse box was retightened. If your dryer had been operating Ok for the better part of a year and then you started to blow fuses on a regular basis.. chances are the wiring coming from the fuse box tap was becoming loose from thermal expansion and contraction and that by changing to a breaker system.. your wiring was cut and reterminated to fit the breaker tap. I suspect you won't be having any additional problems...
Regards,
Rick
SOURCE: where is circuit breaker in a LG DLE9577WM dryer
it could be the thermostat it could be a burned heat element if electric verify gas or electric
SOURCE: LG DLE5977W dryer trips circuit breaker
You could set the dryer to manual dry and then no heat and see if the result is the same. If it runs then, you have a short in the heating system somewhere. If it still kicks out the breaker, you've got even worse troubles. Most likely an electronic board, and what ever caused it to go, like maybe still a heating system issue. I*d suggest calling a qualified service tech for this one. In the USA, you can find one at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
SOURCE: LG M8003L Air Conditioner does not power on
i think there may be damage to a small electrical component in the circuit board which probably fried just before breaker popped open
