GPX PDL805 Portable DVD Player Logo
R
Roger Scharmen Posted on Oct 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need address and phone number to buy replacements
Battery and 9 volt pover cord
Kelley Hopper
Level 2:
  • Expert 67 Answers
  • Posted on Oct 06, 2016
Kelley Hopper
Expert
Level 2:
Answers
67
Questions
0
Helped
33895
Points
172
Amazon sells both the cord and the battery (CR2025). The battery is common and you can find it most places that sell batteries.
https://www.amazon.com/Adapter-Charger-Pd818pr-Yg-pdl907-zebest/dp/B001R2664O
https://www.amazon.com/Sony-CR2025-Lithium-Coin-Battery/dp/B0001MQUOC
They don't have a phone number to call but you can order online.
My lg tracfone ran completly down and won't turn on at all. Battery is less than 7 mo old
The problem will either be a new battery or its charging port. Inasmuch as the phone is only 7 months old, try calling your local carrier store (where you bought it) and see if its under warranty.
If you choose not to, try testing the battery in another phone if you can. If it works, the charger may be the issue. If the phone can be charged from a USB cord, and you have a 12 volt that can be plugged into your car's 12 volt power outlet, try this and see if it recharges (keep it plugged in during a trip to the store. Should recharge in an hour or less). If not, then the battery may need to be replaced.
Here's a link to Amazon. New battery in two days.
$17.50 for OEM on Prime. (As low as $4.50 but I would never buy unbranded junk).
Amazon com LG L41C Cell Phone Battery LI ION 3 8V 1800mAh Replacement For...
tip
What To Do When Your Phone Does Not Turn On
The simplest reason causing a phone not turn on is a dead or drained battery. It happens when the phone gets immersed in water, dropped or allowed to fully drain the battery. The symptom is phone not turning on and not charging the battery. When that happens, make sure first that the battery is not just dead or drained before you send the phone to the service center for repair or before you buy a new battery. You may decide to send it right away only to find out the battery is simply dead/drained or buy a new battery only to find out the phone is dead.
The first thing you can do is borrow a friend’s known good battery similar to yours and try it in your phone. If the phone turns on, you are pretty sure your battery is dead or drained; otherwise, it's time to send it for repair.
When it is verified that the battery is dead or drained or if you don’t have someone to borrow from, try to revive the battery before you buy a new one. You just need a 9-volt battery, a 6-12 volt power supply, or a DC adaptor (6 or 9 volts) and a set of wires.
Connect the set of wires to the terminals of the 9-volt battery, power supply, or DC adaptor whichever is available.
Look for the polarity markings on your battery and connect the other ends of the wires to the battery terminals in the same polarity as the source above. The positive terminal is marked (+) while the negative is marked (-). Do this for 10 to 60 seconds or until the battery gets slightly warm. Do not use this procedure to fully charge the battery.
Insert the revived battery in your phone and charge it until it is fully charged. If the battery works well and does not discharge easily, you don't have to replace it.
In the event that it is not verified whether the phone still turns on or not using a known good battery and the battery is revived but the phone is still not charging the battery, the phone is dead; send it to the service center for repair.
on Dec 06, 2009 • Cell Phones
1helpful
The genarator if there is one regular? gives no pover to the battery
it generates less than 9 amps. they don't need a regulator to control voltage. some generate ac and dc current... for charging the battery is dc and running the headlights is ac
Need a owners manual for model RP-7958
Hi riamb9...
Sorry I could not come up with a user manual for your RP-7958 there was only one page about this remote.
But it did contain a phone and address that may have a manual for your remote..go to the following webpage, and scroll down to the bottom of the page to get there phone number and address.
Give them a call and they may be able to ship you a manual for your remote
Please take time to rate me
Replacement Remotes ' Phone: 336-924-8787 ' Fax: 336-922-7522 Address: 4945 Reynolda Rd, Winston Salem, NC 27106
Phone: 336-924-8787 Fax: 336-922-7522 Hours of Operation: Mon-Fri 9:00AM - 5:30PM EST Address:
(Returns Department)
Replacement Remotes
4945 Reynolda Rd.
Winston-Salem, NC 27106
Replacement Remotes ' Phone: 336-924-8787 ' Fax: 336-922-7522 Address: 4945 Reynolda Rd, Winston Salem, NC 27106http://www.replacementremotes.com/RCA/Buy-RP7958A-54022-Remote-Control.html
3helpful
I lost the battery charger for the BigFoot toy. Can I buy one?
I know you can get these on Ebay. Also most NI-MH 9 volt battery charges will charge this battery pack. You can use a 9 Volt Snap Battery Connector with Alligator Clips to bridge the connection between the battery pack and the NI-MH 9 volt batter charger. This is how I charge this battery pack now. You can probably get the 9 Volt Snap Battery Connector with Alligator Clips at a radio shack or on Amazon... as well as a NI-MH 9 volt battery charger.. don't hook up the leads backwards :)
Phone no longer displays caller id.
if you have a white screen, then your phone need a repair. your flex is damaged. if you're phone is in warrenty, then go to the shop where you buyed your phone. they will send it to a repair shop, and they will give you're phone a new flex. the problem will the gone.
3helpful
2answers
Conair digital answering system
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit will shut down until the power is restored. One 9-volt battery must be installed to retain your personal greeting message and incoming messages during the power failure. Occasionally outside factors, such as power surges, may adversely affect the unit. If the unit is not operating properly or if the light continues to flash once power is restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
2helpful
Line error on caller id
there are a very small capacitor in the board that produce low battery mesege when it get damage, but you gona need a tech to repair your phone there are another problem in your phone its not a seting problem...good luck
Top GPX Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
