Question about Nova Print Artist Platinum Edition Version 25 - Windows
I have windows 8.1 and everytime i try and open print artist it says print artist platinum has quit working what do i do i paid for this program
My program will not work with windows 8.1
  • Nova Master
  • 5,686 Answers
If it was a downloaded software get in touch with where you got it from. If was a boxed software. Try reinstalling it. It might suggest that it's already installed, and ask if you wish to repair or remove it.
Go for the repair option. If it still doesn't work, go for the remove option then and the reinstall from scratch.
Posted on Oct 21, 2016
SOURCE:
My Print artist has stopped working. The Cd rom in my PC is broken so I can't reinstall. What can I do
Print Artist Platinum 24 has stopped working - Fixya
www.fixya.com/.../t13886156-print_artist_platinum_24_stopped_worki...
Aug 4, 2012 - either right click on the setup program and select run as administrator or log in using an administrator account on your PC to install.
Amazon.com: Customer Reviews: Print Artist Platinum 25
www.amazon.com/Nova...US.../B00EPACO3M
Amazon.com, Inc.Find helpful customer reviews and review ratings for Print Artist Platinum 25 at ... Installed this piece of garbage a week ago to start working on a project for a major .... Software performs quite well once the learning stage has been passed.
Support : Nova Development Technical Support
support.novadevelopment.com/
I have a version of Print Artist that came out before version 21. ... When working in the program, it freezes and shows a message "Not Responding" message at the top of ... When exporting a project as a SketchUp file, it has unwanted triangles.
Print Artist Gold 25
Jan 19, 2016 | Nova Development Print Artist Gold 24 no...
Error 1935 while trying to install Print Artist 25
Unlimiting the registry size could work:
Here are the steps:
1) Type REGEDIT in run
2) Navigate accurately to:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
3) On the right pane, locate the following
Key: RegistrySizeLimit [Type: REG_DWORD]
4) Double-click on it.
5) On the dialog box, select DECIMAL radio-button
6) Erase the previous and enter the following number:
4294967295
7) Again select, HEXADECIMAL radio-button
8) Click okay and restart computer
9) Everything will be okay, ENJOY! try to install the package again.
gnaveendra@gmail.com
Feb 11, 2014 | Nova Development Print Artist Platinum...
Runtime error. programme:C\Program Files (... this application has requested the runtime to terminate it in an unusual way. Please contact the application's support team for more information. This is...
If you are trying to import a ms Word document into print artist, they may not be compatible. Try saving the word document as a .txt file and try opening that or importing it in this manner. Sometimes you can just open both programs at the same time and highlight your text on the word doc, right click and select copy ,then paste it into the print artist page.
Dec 21, 2017 | Sierra Print Artist Platinum
Print artist platinum 22 does not want to install on our new computer with windows 7, is there a patch or some drivers that need to be installed?
Try launching the program in compatibility mode. If this is a disc you're trying to install from, click on Start, goto Computer, go into your DVD Drive, right-click the Setup's EXE file, then Troubleshoot Compatibility.
If this is just a Setup EXE file you are trying to load on your computer you can do the same. Just right-click and select Troubleshoot Compatibility.
When you're presented with a list of options, select "This program worked in an earlier version of Windows", then hit Next. Just follow the prompts and then try installing it again.
Feb 23, 2011 | Nova Development Print Artist Version 22...
With a Windows 7 operating system, what product can I find that would be comparable to the old Print Artist 8 Grande Suite? Has Nova come up with anything to compare (I've gotten more recent versions and...
Hi Joni703:
I would recomend running your old Print Artist 8 in compatability mode, since you are dissatisfied with the new programs. to do so, install the program on your windows 7 system, if you have not tried already, and right-click on the corresponding desktop shortcut. When a menu comes up, left-click on properties. at the top of the properties window, click on the compatability tab. Next, click on the check box labeled "run this program in compatability mode for:" and pick the system you have used Sierra Print Artist Platinum on previously. It should function normally.
Jan 12, 2011 | Sierra Print Artist Platinum
New computer running Windows 7. Print Master Platinum will not open. Is there a fix? Ran fine with XP.
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and select the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website.
Jan 06, 2011 | Sierra Print Artist Platinum
Every time I try to boot up print artist platinum edition it says Print Artist Platinum has encountered a problem and needs to close. What do I need to do to fix the problem?
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
Jun 29, 2010 | Nova Development Print Artist Version 22...
Want to transfer Print Artist 4.0 Platinum by Sierra from old computer using Windows XP to new computer using Windows 7. Each effort results in a window appearing which states "Run-time error "5".
This simply means that your Print Artist program is no longer compatible with Windows 7. Some of the support files that used to work with XP is no longer recognized in Windows 7.
One way to resolve this is to contact or visit Print Artist's developer's website and search or ask for any windows 7 support or patches for your version 4.0
Jun 23, 2010 | Computers & Internet
Nova Print Artist Platinum Edition Version 25 - Windows Logo
200 people viewed this question
Top Nova Computers & Internet Experts
 Grubhead
Grubhead
Jay Plesset
Bill Boyd
Are you a Nova Computer and Internet Expert? Answer questions, earn points and help others
