I can't figure out how to attach the quilting bar to the walking foot to quilt
There should be a hole across the back of the walking foot (penetrates the walking foot usually from right to left, although some feet will have 2 guides--one for left to right, the other left to right) where the bar mounts and a screw to tighten and hold it in place.
Quilting Bar Attachment
SOURCE: simplicity so5 needle wont move
There is a device on the right side of the machine to make this work. It is either a knob to turn or a plate to push in. It is located on the right side of the machine in the wheel that turns when the machine is running. This is used to wind a bobbin. The needle doesn't run when the bobbin winder is being used,
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
SOURCE: simplicity quilt n craft owners manual
try
sewingpartonline.com
sew4less.com
sewusa.com
sewingmanuals.com
sewvacdoctor.com
a1sewingmachines.com
Testimonial: "Thanks for your help! I'll check that tonight. :)"
SOURCE: simplicity quilt n craft manual
http://www.sewingpartsonline.com/instruction-manual-simplicity-s05.aspx
here's a link for the manual
No the Simplicity Classic Model S02 doesn't come with a hemming foot. It is too simple a sewing machine. It does have the capability of doing edging and some basic stitches that can be used for hemming, but there is no specialty setting. See the linked pdf quick start guide for more information. http://www.mastersewusa.com/video/S02LetsGetStarted.pdf
