Depends whether the thread is breaking or pulling out.
Usually, timing causes the threads to miss stitches. And, yes, timing can be repaired.
Remove ALL the thread from the machine and rethread from the beginning. Be sure to ALWAYS raise the presser foot when threading. This releases the tension disks so the threads will seat completely. However, it also helps to give each thread a little tug and sometimes the thread will pop when it seats.
If thead is pulling out, be sure to pull a lot (at least 6") of thread tail through before beginning to stitch.
If the thread is breaking, check that it is threaded correctly and that each thread is threaded in the proper order (usually upper looper first, then lower looper with the thread draped OVER the upper looper). Threading in the wrong order will almost guarantee it will not work.
Also check that the tensions are not set too tight. Generally, to start out, set all the tensions at the midway point.
SOURCE: I need manual for white speedylock 1600 serger
Dallascowboy can I get a scanned copy too? I will email you. THANKS
SOURCE: White Speedylock 1500 Serger Manual
I have a 1500 with a manual. I could copy the manual and send it to you. Email me at [email protected]
SOURCE: keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
SOURCE: white speedylock serger 7340 I need the manual and
Singer has the manual for the White 7340 on their site, http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search. The direct link to the manual is http://www.singerco.com/uploads/download/988_sl-7340,299-x.pdf . A universal cord and pedal are avalable here: http://www.sewingpartsonline.com/white-7340-sewing-machine-parts.aspx . This site also has a printed copy of the manual for sale.
I hope this helps.
