Computers & Internet Logo
A
Anonymous Posted on Oct 06, 2016
Compaq Presario SR2020NX will not turn on at all. Any ideas, people?
Presario SR2020NX, 512MB RAM, no OS installed currently. Tried holding power button, tightening wire connections, flipping red voltage switch, nothing works. Green light on rear lights up occasionally. When that happens, power will turn on for a split second and then off again.
magna buff
Level 3:
  • Compaq Master 3,828 Answers
  • Posted on Oct 06, 2016
magna buff
Compaq Master
Level 3:
Answers
3828
Questions
0
Helped
1113719
Points
21593
Ah a tower
you check the power source output
this can be replaced as a whole unit
at power up should be a beep
if the mother board is good it will start up its default
before loading from the hard drive
make sure the dust is removed from all the internals
clean all the contacts
the fans and cards and main board
Compaq Presario SR2020NX will not turn on at all.  - 26302502-xla1id2kzfa3gc1k0hv4dqvn-3-0.jpg
Testimonial: "Okay, I'll try that, but I'll keep this open just in case."
  • magna buff Oct 06, 2016
    yes good idea to keep it open .hope the mother board is good .dust is the number three enemy of towers
I have compaq presario V3070TU with 512mb ddr2 RAM. i tried to upgrade to 2 gb RAM into one bottom slot (not 2 numbers of 1GB), but 2gb RAM is not working(display is not UP). only 1gb RAM is working....
I could not figure out the relationship of the hard disk with the memory.
try change the memory dimms put 512 in bottom and 1gb in the other possition and see what amount of ram you get
2helpful
2answers
Have a COMPAQ PRESARIO SR2020nx want to upgrade the memory it have 512mb how high I can go up on the memory
  • Two 240-pin DDR2 DIMM sockets
  • Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs
  • Non-ECC memory only, unbuffered
  • Maximum HP/Compaq approved memory is 2 GB
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
Yes.
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245048
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
NOTE*
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI-Express
For additional questions please post in a Comment.
(Top right of your page, blue Comment)
Regards,
joecoolvette
3answers
What's the maximun of ram memory that compaq presario 6025ea can admit?
This is an older model computer, and therefore it can't utilize the large amount of RAM that more current models can.
The Presario 6025EA has two DIMM slots and comes with 256MB of RAM installed. The maximum amount of RAM that can be installed is 1GB. To upgrade to this, you will need two 512MB DDR-266 (PC2100) RAM modules.
If you found this solution helpful, please leave a positive rating!
2answers
CAN THE HP Compaq Presario SR2020NX PC DesktopCAN UPGRADE 1GB RAM, I TRIED INSTALLING TWO MICRON 1GB 1RX8 PC2-5300U-555-12-ZZ MT8HTF12864AY-667G1, BUT THE SYSTEM IS ASKING FOR SOFTWARE TO INSTALL IT. I GOT...
Your new RAM is PC2-5300 .It is more than supported by your Computer.
Your computer model will support Max of 2GB RAM but speed supported is PC2-4200.
Thanks for using FixYa.
My daughter plays World of War Craft all day! I want to help her upgrade her computer... So what is the best video card to get for a compaq sr 2020 nx?
Graphics Controller
  • Type Integrated
  • Graphics Processor / Vendor NVIDIA GeForce 6150 LE
  • Video Memory 256.0 MB (max)
Upgrade your vbideo card more thant 512mb minimun 1gigas is the best.
also upgrade your memory ram
3answers
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
Presario 700 US
The Compaq Presario 700 US Will only hold a max of 384mb of PC133 RAM. 256mb is the biggest chip you can add.
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
