Question about Nortel IP Phone 2004 NTDU92BD70E6
Voicemail will not pick up external calls. continues to ring and finally hangs up
Panasonic EL52253 cordless phone: after completing a call, the in use light on the base remains lit unless the user presses the red OFF button on the phone. Can this shutoff be made automatic?
great job at asking the question. so much better than most on this site. I would try deregistering all the hand sets and then re-registering the base unit handset. see pdf instructions:
http://www.brandsmartusa.com/pdfs/manuals/20182728.pdf
May 05, 2017 | Panasonic Office Equipment & Supplies
How to change number of rings on VTect cordless CS6114-11
The CS6114-11 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 30, 2014 | VTech Communications CS6114 - cordless...
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
Voicemail not picking up
Your unanswered calls go to voicemail if your phone is set to call-forward-busy-no-answer. If that got cancelled by mistake, then your phone will ring until they hang up or you answer. These phones work on a bunch of NEC systems, so I don't know what your cfbna code is. On the Pro II, the Elite, and the IPK, the code is 43 plus voicemail pilot number, if your codes are at default.
Jan 17, 2014 | NEC Lands Phones
Extend number of rings before answering machine
The 6041 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
Please refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and specify the answering machine or voicemail system.
Dec 26, 2013 | Vtech Cordless 6041 Phone
How do you change the amount of rings on the uniden dect1363 6.0 GHz
The Uniden DECT 1363 isn't an answering machine. It will continue to ring until someone picks up, a separate answering machine or voicemail system picks up, or the caller hangs up. You need to refer to the documentation for your answering machine or voicemail system.
If you require further assistance, please repost your question specifying the make and model of your answering machine or voicemail system.
Sep 18, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
Need more rings before going to voicemail
The D1660 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up. Please refer to the documentation for whatever answering machine or voicemail system you have connected to your phone line.
If you need further assistance, please repost your question but be sure to specify the make and model of your answering machine.
Sep 02, 2012 | Uniden D1660 Cordless Phone
Hi How ldo I set the # of rings on my phone Model# EXP4240
The EXP4240 isn't an answering machine. It will continue to ring until the caller hangs up or some other answering machine, fax, or voicemail system picks up.
Mar 17, 2011 | Uniden Cordless Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Nortel IP Phone 2004 NTDU92BD70E6 Logo
Top Nortel Radio Communications Experts
ka4iup
ka4iup
Norm Pearl
MrFixitSTTL
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
