Do it line up the timing marks together? or do I place them on opposite sides?
SOURCE: crankshaft pulley timing marks
the red mark is where the timing is supposed to be after u have bypassed the electronic advance.the first white line on the left is tdc.
thanks for useing fixya
SOURCE: 1996 timing belt changed, lined up all the marks,
Hi my name is juan and lets try to solve this it is possible that when you rotated the camshaft the distributor last his position and this is why it won't start it may not be the problem but this happens a lot so open your distributor and aline up your marks on camshaft and the crankshaft then make sure the distributor is pointing near the #1 spark plug if is opposite give it a 1 more turn to the crankshaft line up your marks again and se what happens #1 spark plug is the closets to the front part of the engine on 4cil
SOURCE: How to line up no1 cylinder on TDC on 1998 Daewoo
this is a trick that will work on any conventional motor.
1. sit a piece of wire in the spark plug hole long enough to touch the piston @ half stroke and not fall in = mark the spot with a correction pen on the pully
2. holding the wire in place, turn the crank away from the wire until the piston touches the piston again = mark the spot
3. measure half way between the marks and mark with easily visable mark.
happy motoring
SOURCE: Timing marks on cam sproket and crankshaft pully 1996 Elantra 1.8
dear friend-if your mark at the bottom is on TDC then that is fine,there is a 8mm hole in the top sprocket.alighn the hole with the mark on the cylinderhead,put belt on and tention turn ones around and lighn up marks.re-assemble.
SOURCE: toyota 98 camry v6 cambelt timing marks
Click on the following free direct Link. It has the Timing: Belt and Mark Diagrams for your 1998 Toyota Camry. Plus additional Instructional and Directional Diagrams.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1998/make/toyota/model/camry/1998_toyota_camry_timing_belt_diagram_marks.htm
