Washing Machines Logo
Della Durling Posted on Oct 04, 2016
I have a Kenmore Elite washer model 110.2803 or 04. The washer won't do anything but make a crunching stalled sound. no error codes. Have to unplug it.
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Kenmore elite he3t quietpak 4----F25 ERROR CODE...WHAT NOW??
The F25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then re-seat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
2helpful
Washer won't unlock flashes f14.....Kenmore Elite HE4t
F14 for Kenmore (Whirlpool) machines means EEPROM Error.
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU, if there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error. Check CCU. So its likely you'll need a new CCU board.
Check your owners manual, some models have up to a 5 year parts warranty on that CCU.
1helpful
2answers
Kenmore elite he14. What is the f14 error?
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
11 minutes timer flashing, machine locked
unplug washer over night. plug in try drain and spin, if it works after finish try to restart. an 11 minute stall is likely error code f / 11 or dl code starts intermittently then goes out possible ccu board under top at rear
Kenmore Elite Calypso Washer
take the pannel off the bottom and unscrew the pump cleanout
2answers
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Alexander
vince
