Most android devices can download apps from the Google play store. Some brands try to hook you to their brand. Just find out what Google can offer. Google Play
Google Play Services, the preinstalled app on your phone plays an extremely crucial role in the regular running of your lenvono. If anything is wrong with it, then your lenovo will start throwing fits in the form of errors and crashes including 'Google Play Services keeps stopping' error.
To remove the error, you need to fix Play Services. Here you will find numerous ways to fix any issue related to Play Services. Let's get to know them.
1 Starting with, will actually with restarting you Lenovo.
2 Another that does wonders for any issue is to "clear the cache" and date of the particular app. In this case, we need to clear cache and data for "Google Play Services" and "Google Play Store".
Doing any of that will not delete any data from your phone. However, clearing data will log you out from Play Store and reset its settings. In settings
3 "Google Play Services" is a system app, you cannot remove it from your lenovo completely. However, you can uninstall the updates, which will revert it to the factory version forcing your phone to update it automatically, thus fixing any issue.
On the Google Play Services screen, tap on the "three-dot" icon at the top-right corner. Select Uninstall updates from the menu.
4 Unlike other installed apps, you don't have to update Google Play Services manually. It's done automatically in the background by your lenovo.
However, sometimes, the issue is with the update itself. So you need to update it to the newer or older version manually. We have covered ots of ways to update google play service in detail. Do check that. And if you face any issue while updating it, check fixes.
6 Similar to restart, sometimes booting in the safe mode fixes various issues on an Android phone. Again, doing that will not delete you data and you can access it in safe mode as well. Running the lenovo in safe mode also helps in identifying the issues caused by the third-party apps.
I hope these will get you over your issue with ease.
Google Play Services needs to be updated from time to time. It seems to keep getting bigger and bigger. You can go into Settings - Apps and then ALL and scroll to find Google Play Services and then click on it. The screen that comes up will give you the option to clear the cache and clear the data.
First clear the cache. Then see if that solves the problem. Likely it won't. Then you can clear the data. It that doesn't work for you then click on *uninstall updates.* This will reset the Google Play Services to original factory. Reboot and make sure you have a good wi-fi connection as the Google Play Services should connect to the Google Play Store and update automatically. If it doesn't, then open the Store app and select *My Apps* *All* and scroll to Google Play Services.and click *Update*.
Note: the Store App, itself, might be slow and balky until the updated Play Services is installed and running.
Here's a hint. If you do the above and delete the updates from the Google Play Services app on your device, when you boot up your device might act balky - just give it a few minutes as it's probably connecting and downloading the Google Play Services updates automatically. Google Play Services is important for just about everything that communicates with Google so don't expect all the other Google apps to work until the updated version of Google Play Services is installed and working.
When you uninstall updates to Google Play Store you are actually uninstalling updates to the Google Play Store app itself and not your other installed applications and their settings what you're actually doing is downgrading the Google Play app itself to the version that came shipped on your nook HD Plus. I know this Uninstall Updates wording tends to freak a lot of folks out because they think it means all updates to everything. In the app itself sometimes this is necessary if a bug is introduced into the most recent version of the Google Play app. Don't worry over time the Google Play app itself will automatically update itself again. If newer versions still have a bug on your system just uninstall updates again until they get it fixed. Over the last two and a half weeks a minor bug was discovered in Google Play that the very second you entered an apps description page Google Play would immediately stop responding to the system and crash. I sent a blind email to a Google support email address I hoped could forward it to the Google Play staff. I sent the email in about this problem about a week ago. It least on my Nook HD plus for the past two and a half days this problem seem to have corrected itself. Knock on wood.
You are the second question in a week about this very same problem between the Google Play Store app and Nooks. Hope this answers both questions and provides a solid workaround should Google Play Store ever get buggy again in the future.
Below is a short video on installing Google Play. Often, when we install an application in that same place will be an option to update to the latest version. Checkout the link.
Try going Settings>Accounts>Google> Tap your account> Three dots in the upper right (or press menu button) "Remove Account" ... then read your account .. then if you want, clear Play store cache and data and try it
