There is a button on the base NOT the phone
GE 6.0
There is a button on the base NOT the phone, i felt like an idiot after finding it, I hadn't even looked at the base.
I'm guessing that you didn't mention that the phone doesn't work, it must be in FWD mode. You can cancel CF, or get someone to go into 990 area 9 bit 3&4 and reverse the bits so it will be solid on FWD and flashing on DND.
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
One doesn't necessarily equal the other, but start with the DND first :-)
Press FEATURE #85. DND off. (FEATURE *85 puts it back on).
Now, if everything works, skip the rest. If not, press FEAT *0 and press all the buttons on the strip below and above and note what it says. It should match what other phones have programmed. If it doesn't, post back as a comment and we can start working on that.
It doesn't exactly work that way, but you can program the extensions back under the buttons. Pick a button that you want to save an extension under and press FEAT *2 the button and dial the 2 or 3 digit extension number. Now the button monitors the status of the extension. It will light whether it's in DND, or busy on an outside or internal call.
