The unit will power up and connect to satilites but goes no further.Press any button and nothing happens.To turn off the power has to be disconnected
SOURCE: unit wont turn on
.Hi jepenny
The board you are looking at is the standby cct and power switching PCB. It sounds like that is working, so you have probably lost power to the transformer primary or the transformer is open circuit. Check for blown fuses and replace with exact same type and rating.
Be sure to unplug at the wall before touching any internals!!
If you can find no blown fuses, the power transformer may have failed. Good luck, get back to me here is you need any more advice. Thanks for using "FixYa"
regards
Graeme
SOURCE: Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
SOURCE: I have an Emprex Model WT323 LCD tv.
Does the lights on the front have a pattern to them or does it just turn on green and stay that way? If the lights have a pattern or turns on green then goes to orange or some other color then I would start with the power board. If the light stays green the whole time then I would turn all the lights off and shine a flashlight up real close to the screen and see if you see anything. If you do then it is your inverter board which controls your backlights.
Good Luck
SOURCE: Monitor will not turn on. Power to the unit OK.
It can be the power switch actuator is broken, it is badly designed for expensive monitor. Do you feel any clicking when you push on the power button?
See my pictures here and post back what you find.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E228WFPc/
If it is OK, then you will need to dig deeper into troubleshooting it.
Testimonial: "The button does seem to have a "dead" feel to it. I will take it apart to trouble shoot it tonight. Thank you very much."
SOURCE: TV won't turn on
my mitsubishi tv wont turn on .when i push the power butten it just click i don,t know what to do help please ps modle # vs-4517s
