Great Picture on the TV but now I somehow locked it out
SOURCE: black box in bottom of picture
Check your cc mode setting and turn it off(after noting the setting,)if this cures the problem dont use the setting noted above
SOURCE: No Signal through on my main TV input.
This may be the tuner or IF module that is failing. It may also be a voltage supply fault to these modules. It is impossible to accurately speculate without actualy troubleshooting the set.
Jerry G.
SOURCE: tv turns on but takes about 20 minutes to show the picture
This is the picture tube. If you check shops you can find one that has a picture tube restorer. If they run just the cleaning process it will buy you some time. This is good some times for up to a year
SOURCE: TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
