Measuring Tools & Sensors Logo
M
Marg Penn Posted on Oct 03, 2016
La Crosse remote weather station. The receiver won;t receive the outdoor temperature
I have replaced the batteries in the outside sensor but the indoor receiver is still not showing the outside temperature
1 Related Answer
kebomachy
  • 22 Answers
  • Posted on Dec 21, 2014
SOURCE: why does my outdoor temperature show a constant 35F?
It might not be in range I wouls try bringing them closer together or bring your outdoor sensors inside untill yoh get a reading
Testimonial: "I brought the outdoor sensor inside, installed new batteries, tried moving them closer together. I still continue getting a reading...always 35.5F. Never changes...why???"
La Crosse Technology WS-9160U-IT Digital Thermometer. The outside temperature stop working. I tried new batteries.
Question edited for clarity. Full 'make model (what it is)'.
Did you put batteries in both units and in the right order, sensor first?
Step 1: Insert 2 fresh AA, batteries into the TX29U-IT sensor according to the polarity marked in the battery compartment.
Step 2: Insert 2 fresh AAA, Alkaline batteries into the wireless thermometer according to the polarity markings. Step 3: After 5 minutes place sensor outside in a shaded location.
https://www.lacrossetechnology.com/products/WS-9160U-IT#support
Retired unit so no further warranty or parts.
You can still get one on Amazon
La Crosse Technology WS-9160U-IT Digital Thermometer ...
Amazon.ca https://www.amazon.ca > Technology-WS-9160U-Digita...
Digital thermometer with wireless remote and clock; Remote sensor transmits from up to 330 feet; records daily high and low temperatures; Receives weather ...
Rating: 4.4 · ‎ 7,970 reviews · ‎ $31.50 · ‎ In stock
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
1helpful
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. taylor.norman1@gmail.
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
7helpful
How do get the outside temp to work.
Bring the outdoor sensor inside. Take batteries out of both the sensor and the main unit. Wait 10 minutes. Put batteries in remote sensor. Then put batteries in main unit. Don't touch any of the buttons for 10 minutes or until the outdoor temperature is displayed. If still not displayed after 10 minutes then try again.
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
