Is there a universal cable to connect a Humminbird fish finder to a Motorguide trolling motor because Motorguide wants a Lowrance not Humminbird & Humminbird is compatable with MinnKota
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
SOURCE: Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
SOURCE: go about getting operational anual for fish finder humminbird
I found what you are looking for. Go to: http://www.humminbird.com/support/FAQ.aspx?faqid=72
You can download the operating manual.
SOURCE: i need a manual for humminbird wide 100 fish finder
You can find the manual you need at: http://www.humminbird.com/support/FAQ.aspx?faqid=72
It is listed in the legacy products area with the wide series of units.
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
SOURCE: Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
