If you wish to get some details about treadmill calibration and error code troubleshooting then check the following link.
http://electro-medical.blogspot.com/
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: Elevation Will NOT go down after the elevation calibration
Unplug unit and remove motor shroud if you are savvy with a multi meter then try these trouble shooting procedure:
Perform and elevation calibration again, On the display, can you see numbers counting down and up and the treadmill is going up and
down? If yes then the unit will proceed to work, if no when power is on, check on the lower board, on connector J5, do we have 5V DC between pin 1 & 3?
If yes During Calibration, J5, between Pin 5 & 6, on the lower
board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 4 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 2 & 3, on the lower board,
do we have DC voltage varying from 1.15 to 3.00? If any of the above is no then then the lower board will need replacing if all is yes then elevation motor needs replacing.
SOURCE: nordictrack c2050 treadmill is stuck
Watch this videos+ tip:
http://www.youtube.com/watch?v=bF3OyQ3HwfU
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=Uzf4az4RRDE
http://www.youtube.com/watch?v=MIIxoPtvhy8
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
You need to call Icon ASAP and get a tech out under warranty to fix the issue.
Testimonial: "Very helpful. Thank you "
SOURCE: How do I fix my Nordictrack Elite 7500? The incline is stuck and won't move up or down.
1) Lube the elevation motor, see the diagram, parts gear + shift
2) adjust the POT, for a little and see if there are better improve.
3) RUN the software calibration for diagnose, troubleshooting, fix it.
God bless you
