Cars & Trucks Logo
Andrew Woods Posted on Oct 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Volvo 440 96 manual no reverse gear motion but 1 to 5 gears going ok engine not switched on into reverse with reversing light on back start car no revers is this clutch problem or worse thks
Will not select reverse gear while engine running forward gears ok
Lawrence Oravetz
Level 3:
  • Volvo Master 10,558 Answers
  • Posted on Oct 02, 2016
Lawrence Oravetz
Volvo Master
Level 3:
Answers
10558
Questions
Helped
2700090
Points
29284
It's inside the transmission. The shift yoke probably has worn so much that it no longer moves the gear inside.
Volvo BL71 Backhoe Loader. It is jumping out of gears on reverse and in forward.
This is not a quick fix. Check fluid levels as the switching is hydraulic. You may need to consult a transmission expert if the synchro is failing.
The machine's Power-shuttle gearbox features four fully synchronized gears and electro-hydraulic switching between forward and reverse. For better balance, the transmission is mounted directly to the engine.
https://www.volvoce.com/-/media/volvoce/global/global-site/product-archive/documents/04-backhoe-excavator-loaders/04-volvo/v-bl71/v-bl71-bl71-plus-21c1002689-2010-04.pdf?v=HSEyPw
and
https://www.google.com/search?q=Volvo+BL71+Backhoe+Loader.+It+is+jumping+out+of+gears
'97 volvo 960, Orange W-mode arrow blinking, then lost power. What is wrong?
The usual cause of this is a bad PNP switch or gear position sensor.
The "W" is flashing because the transmission control module is stuck in the Winter mode. If you are not familiar with sensor, I suggest you go and have the transmission codes read and reset to begin with and then post back the results.
1helpful
The reverse gear is fine but when you let go of the gear stick the reverse lights go out and light pressure put back on gear stick bits lights back in
Ok! This is the reverse light switch located under the gear stick gaiter! Could just need adjusting.....double nut locking system or is faulty/broken! The switch has a plunger that is activated by the movement of the gear stick to reverse!
2helpful
2answers
Why did my car stall when in reverse gear?
I need a little more info. I presume it is automatic, not a manual trans. Was it multiple times that it stalled when you shifted to reverse? or just 1 time. Is the check engine light on, and/or the D4 light flashing?
Automatic gear problem
Your tranny\'s going. How many miles. May have bad sensor/sincro or electrical problem.
Volvo xc70--engine starts but truck doesn't move when put in gear
check tranny fluid.if fluid level is correct.change fluid and filter if its been a long while.if it still wont go into gear.your tranny oil pump is worn.and the forward clutch seals and drive plates worn.
S80 backup light wont work
There are only 2 things to check other than the bulbs, 1st the back up lite fuse, and the 2nd the back up light switch on the trans, if the fuse is ok replace the backup light switch.
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
