Watches Logo
John Brown Posted on Oct 02, 2016
Jia heng lighter watch parts and configuration of components?
1helpful
2answers
Where to get a colibri lighter repaired
I repair most Colibri Lighters out there. I bought Colibri's repair department. Please check out. Beam Sensor Lighter and Touch sensor.
Cleanlighter.co
[email protected]
Where can I buy a new reservoir for my cartier lighter
I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
I have a dunhill lighter pat. #3910750 des. pat. #235456. When I fill it with butane, it leaks out of the top of the lighter. What is causing this?
Sounds like the valve that regulates the gas flow is sticking in the open position even when the lighter is not in use. Try spraying a light machine oil like WD40 on the gas jet aperture and any other moving part whilst your at it. Wipe excess oil from the lighter and leave for several minutes for the oil solvents to evaporate. Light the lighter a few times in rapid succession to enable the oil to penetrate. If the oils done it's job the gas should no longer leak.
Jan 02, 2014 • Watches
1helpful
2answers
I want to buy a Cartier lighter but I want to make sure it,s real. How do I look up the serial number?
To look up the steel ligter serial number is very easy ,I specialize in buying and selling Cartier watches. I've seen fakes with all the correct marks and a serial number, but that doesn't mean they are legitimate. If the watch was registered by Cartier when it was sold or if it has been sent in to Cartier for service Cartier will be able to verify it is authentic, but be aware that if the watch was not originally sold in North America or was not registered when sold (fairly common) it can still be authentic. Some sellers offer the Cartier quartz model for sale and only state that the watch has a quartz movement, but fail to mention if it has a Cartier quartz movement. If it has a replacement movement in it the watch is technically authentic, but not original and is not worth as much as one with an original or a genuine Cartier replacement movement. The biggest mistake I've seen amateur Cartier buyers make is using the Cartier micro-script signature on the Roman numeral to verify authenticity. Indeed this is a good indicator, but not the best indicator as there were many Cartier watches produced prior to the technology required to make the micro-script possible and not all Cartier watches have Roman numerals for the dial to have the micro-script signature. Furthermore, the micro-script is not always located at the same place and if the dial has been refinished it may not appear at all. Another common problem is actually caused by language differences, i.e. "all original versus "authentic". A watch can be authentic without being all original. Unless someone has owned the watch since it was new and it has never left their sight it is impossible for them to state the watch is "all original" as a part could have been replaced at some point in time -- even without their knowledge. Your best bet is to buy from a reputable seller even if you have to pay slightly more money. -- Cartier_Specialist
May 08, 2012 • Watches
1helpful
My problem is that i can't find an postal or email address for somewhere reliable that i can send my old colibri 'molectric' cigarette lighter for repair. can anyone help? this lighter has great...
mcdevito75 here, Hello Dave, My advise is to take your lighter to a jewelery shop, you can try a small place, they may have the info or even repair your lighter. Also try Colibri watches.com try and see.
Feb 11, 2011 • Watches
2helpful
Got my wife's salt water damaged timex heart rate monitor watch here. Opened it up, and one corner of the screen looks a bit faded and there's white corrosion mess. Can I dip in metho to clean away residue...
Do not use any chemicals. They will damage your watch. The only thing you can use is ZIPPO, RONSON e.t.c. lighter fluid, but do not dip any watch parts in it. You have to use cotton swabs. Dip the swab in lighter fluid and then clean the parts. Do not use a lot of pressure. Change the swabs constantly and blow off excess of lighter fluid all the time. It will take a while, but this is the best solution. When part is clean enough, use dry cotton swabs to clean off the oily residue. Rate me, plz.
WHERE CAN I GET A RESERVOIR FOR MY CARTIER LIGHTER
The reservoir tank can be the bane of existence for a Cartier lighter owner. Unlike most butane lighters which have gas tanks integral to the lighter, Cartier utilizes a user removable tank. Cartier only warrants the tank for two years. I've also seen tanks that say 12 months. New Cartiers come with one spare tank. I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
1helpful
Pocketwatch runs fast
Such a fast gaining usually is caused by dirty or magnetized hairspring, resulting in uneven coil amplitude (some of the coil rows are sticking together or touching each other). This causes the watch to run unbelievably fast.
To get the watch properly fixed you need to give to the watchmaker.
Alternetively; you can fix it yourself, but it will not last long.
For this you will need:
Case opener,
Dust blower (resin ball with nozzle),
Lighter fluid (ZIPPO),
Dropper (like one in eyedrops package).
Do as follows:
Open watch caseback,
Check for the fastest moving part in watch movement and you will see the hairspring fitted on it (pulsing outwards and inwards very fast).
Fill the VERY CLEAN dropper with lighter fluid.
Put ONE drop of lighter fluid on hairspring (DO NOT TOUCH IT),
Wait for a 10 seconds,
Dry out the lighter fluid with dust blower by vigorously squeezing it and pointing the nozzle on to hairspring from approx. 2-3 inches away.
Lay the watch on the table (dial down) and cover it with a clean, dustless cup. Leave for 15 minutes.
Fit the caseback on and enjoy your watch again.
Do not forget to rate, please.
4answers
Dunhill cigarette lighter spare parts needed
Hi, Dan, I have 2 Dunhill ighters that work but they leak butane. Making them unfit for use. I would like to have them repaired/rebuilt. I believe they are 1960-70's vintage so, the lack of parts will definately be an issue here. Please advise. Thanks Glenn [email protected]
Jan 30, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
