Only the person that set the code can get into the phone. A hard Reset is the only way, scrub it clean and reload the OS. There is no magic way involving the IMEI number. If it says PUK Lock, that is a whole new level of grief!
You need to enable Wi-Fi Calling manually if you want to use it.
Ensure your LG Stylo ™ 6 is powered off.
Press and hold the. Volume Down button. then press and hold the. Power button. ...
From the 'System recovery' screen, select. Factory data reset. . ...
Have LG Tech. Supp. walk u threw it, or while booting up press and hold power button and volume button simultaneously, you will come to a list of options, highlight factory reset and follow instructions. If this is a stolen or you found this phone, you might want to return it. Even after factory reset you will need, email, full name etc. when reregistering it...hope this helps...
If you want to set it back to factory reset, then turn your phone off. Press and hold the power/lock button and the down volume button at the same time. When you see the factory reset screen then release both keys. Hope this helps.
If you have a Google account linked on your phone you can just unlock it with your login info. Or you can factory reset the phone in recovery. But you'll lose everything on the phone.
you can enter your code in the following way. LG Android Phones
Start your LG Optimus GT540 Android Phone Click the icon to open the phone dialer Enter 2945#*540# and press send Enter the provided unlock code (which you have purchased) Click 'Unlock' , then it's done. Your LG Optimus GT540 must be unlocked now, have a good day! LG Phone Problem and Solution
You can't just reset to default factory setting to use that phone. That phone need unlock code and you can get LG GW300 unlock code from your vendor provider with some charge up to $80 or you can buy lg unlock code from third party sites with more cheap price.
1 Connect phone powered off
2 Add power to clip
3 Wait for correct Stage Mode then press power button on phone
4 Keep phone power button held until 2 solid LEDs on clip
5 A factory reset maybe required to finish unlock
Factory Reset
If the phone is still locked then power on phone and enter 2945 select factory reset
To unlock lg gt365 you must have lg unlock code for your carrier network. With this unlock code you can reset your phone network to default factory setting so you can easily change your sim card with other sim card from another network provider.
