Washing Machines Logo
Regis Espinoza Posted on Oct 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Controls for skid steer 2002 case 1845c are locked
Controls for loading bucket are locked
Bill Boyd
Level 3:
Top Expert:
  • Washing Mach... Master 53,816 Answers
  • Posted on Oct 02, 2016
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925532
Points
172802
Check seat belt , safety bar and other safety switches for correct operation
Diesel hand pump wont pump. on CASE 1845 DEISEL
u'd need a proper manual for this in my opinion
like there are plenty of dealers and online shops that deal in those..
you can checkout https://www.reliable-store.com/products/case-1845-1845c-skid-steer-backhoe-loader-service-manual
How do I adjust creating on 1845c case skid steer
Cat® Skid Steer Loader ' Drive Chain Adjustment ... - YouTube
? 1:39
https://www.youtube.com/watch?v=FUtx88JifxY
Sep 27, 2011 - Uploaded by Cat® Products
Cat® Skid Steer Loader ' Drive Chain Adjustment & Chain Oil. Cat® Products ... Crane picking a skid steer out of a building. Unsafe - Duration: ...
How to change a drive chain on a case 90 XT - YouTube
? 2:27
https://www.youtube.com/watch?v=WBWVSpgZkKQ
Dec 27, 2014 - Uploaded by rayray haque
I made this video because I recently had to fix the drive chain on my skid steer. But there were no easily ...
Case 1845C Chain adjustment question - Heavy Equipment Forums
www.heavyequipmentforums.com/showthread.php?...Case-1845C...adju...
Mar 6, 2012 - 15 posts - ‎5 authors
I noticed it was making a popping noise in the front left wheel, so I. ... It appears that this skid steer is pretty much indestructible if taken care of ... Case 1845c Skid Steer Problem - Heavy Equipment Forums
Apr 21, 2013
Case 1845C Uneven speed while travelling
Nov 24, 2012
1845c what things go bad - Heavy Equipment Forums
Jun 9, 2009
1845C Fan belt change question - Heavy Equipment ...
Apr 9, 2009
More results from www.heavyequipmentforums.com
Bobcat skid steer
I know on a bobcat 773 there are 2 spool lock soleniods. They are on the front of the bucket control valve. They literally lock the valve by a spring loaded pin that goes in a groove on the spool. When they get juiced the pin retracts and that spool can move. One for lift and one for curling the bucket. Check the wires coming out of the solenoids. Unplug them one at a time and see if the code comes right back. That should narrow it down to which one is bad. I changed both but compared ohms.
May 27, 2013 • Toys
2answers
773n bobcat will move forward and back but wont raise bucket
Bics coil on control valve not unlocking. Broken wire, bad connection or bad coil
My 1845c skid loader is not pulling forward nor in reverse
have a case skid loader 1845c. when asked to go in reverse after applying pressure to go in reverse the left side does not respond, but after a couple of seconds will go in reverse. does any opne know what the problem could be? Thanks
I have a 97' daewoo dsl601 skid steer that the boom and bucket won't move
You most likely have a defective hydraulic control valve, I would start the testing there.
2answers
1845C Case skid steer wll not start every time. Is there a safety switch on this, besides the bar you pull down?
What year is your case? It will be either the Ignition cylinder or wiring short if an older model.Could also be your starter solenoid.
15helpful
2answers
Need manual for case 1845C skid steer
My 1994 1845c case skid steer, Drive assy won't go forwards or backwards on right side tires.Left tires will operate fine.looked into chain area fluid was up, chains okay but fluid looked milky compared to the left drive assy.Could it be the right drive pump that has gone to heaven? When I bought it 2 years ago I noticed the right side DRIVE TRAIN was not as fast as the left when going forwards too.Could you please give me an idea where to look first? Thanks Frank
Top Washing Machines Experts
john h
