Sony Bravia XBR-Series KDL-46XBR4 46-Inch 1080p LCD HDTV Logo
m
michael pedone Posted on Oct 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony bravia kdl-46Xbr4 right side of screen is darker until the tv warms up flickers like a floresent bulb and is a brownish color
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Oct 02, 2016
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14991955
Points
237762
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Can this be fixed ? what is the problem?
What your describing sounds very much like a video board issue some part is not working properly until it warms up. Eventually it will most likely need to be replaced, If you are not sure what board or part is bad, in the long run it might be a better idea to just replace the TV.
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
7helpful
3answers
I have coloured vertical lines covering my Sony Bravia LCD tv screen. The TV is only 2 years old. I have sound but a very distorted picture. The cable company has checked and says it's a tv problem. I will...
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
3helpful
Sony KDL-46XBR4 much darker on the right side of screen
ITS THE PANEL ASSY. I JUST HAD MY REPOACED. SONY WILL HONOR A COURTSEY WARRANTY UNTIL 2012
Dark area on Sony LCD screen model KDL-46XBR4
This model of SONY TV uses a Samsung display panel, the problem you have is the panel went bad.
SONY was offering an extended warranty to change the panel free, please call SONY to check it out that if they still offer the free replacement.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
