Cameras Logo
v
valerie Clark Posted on Oct 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I use this camera? - ViviCam Vivitar Cameras
Tony Parsons
Level 3:
  • Vivitar Master 6,405 Answers
  • Posted on Oct 01, 2016
Tony Parsons
Vivitar Master
Level 3:
Answers
6405
Questions
Helped
1651392
Points
20272
  1. Switch it on
  2. look through viewfinder or at screen
  3. frame your image
  4. press shutter release
Are there any firmware updates for a Moultrie Model# MFH-DGS-135
MFH-DGS-135 trail camera upgrade software - Moultrie
https://www.moultriefeeders.com > catalogsearch > result
Items 1 - 36 of 219 - Search results for: 'MFH-DGS-135 trail camera upgrade software' ... Camera battery tray 6 c batteries · camera's manual mfh-cdc-501 ...
Moultrie M-Series Game Cameras ' How To Update Firmware
https://www.youtube.com > watch
PREVIEW
3:13 Update the firmware on Moultrie M-Series cameras in a few simple steps. Remember, if the camera has ...
YouTube · Moultrie · Aug 19, 2016
I can't transfer photos from camera to computer
Go to Nikon website and load up the Nikon Camera Control Pro2 software.
Then connect camera with the USB Cable from camera to computer.
Turn on camera.
Wait or click on Nikon Camera Control Pro2's Icon.
Have put in the SD card into my camera before doing the set up via the PC on my new olympus sp800UZ camera can you help as I cant seem to use the camera
If you did not format the internal camera memory, you can initialize and install: Set the camera to OFF. Remove the SD card and connect the camera to the computer with the USB cable. The computer and camera should negociate and the camera should initialize and it asks to install the software.
2answers
COULD NOT OPERATE THE CAMERA
When a camera doesn't not start , it means that the camera display is bad. You will need replace camera with another before camera will work.
Meanly caused by VIRUS.
replace camera.
We cannot view camera images on TV from G2. We could in the past. Image in camera viewer goes blank when plugging tv cable into camera. Tried new cable. Still the same. Has something failed in camera?
Hello. I'm not sure if the camera has failed but try this sequence.Plug camera into tv then turn on camera then push review button. This is the only way 2 of my cameras will work for tv viewing.
Builderdale
2helpful
2answers
Camera suddenly began reading "lens error - restart camera" and lens will not retract. camera was not dropped and no foreign material was introduced to lens (as far as I know) please help! i love my camera...
Hi
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.
Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. Please do rate this solution as FixYa and revert for further assistance. Thanks
Rylee
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
