R
Ralph Zucker Posted on Oct 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The shredder won't start and stop automatically. I need to turn it on and off each time I use it.
Jeff
Level 2:
Sergeant:
  • Expert 204 Answers
  • Posted on Oct 01, 2016
 Jeff
Expert
Level 2:
Sergeant:
Answers
204
Questions
0
Helped
61651
Points
575
Most shredders have a small sensor on the top that keep it from running when there is something near the top, like fingers, to prevent injury. It is possible that over time, dust or small bits of paper are covering this, keeping it from operating properly. Unplug the shredder then wipe down the top with a slightly damp rag, checking near the feeder opening for anything that might be stuck there.
Also look on the bottom near the teeth and see if there is a contact switch that is dirty or not sitting down properly.
2answers
HSM Securio B24 paper shredder
The HSM Securio B24 is a high-security paper shredder that is designed to shred sensitive documents into extremely small particles to protect against identity theft and other types of data breaches. It is capable of shredding up to 24 sheets of paper at a time and can also shred staples, paper clips, and credit cards.
To use the HSM Securio B24, you simply need to place your documents in the feed opening and push them through using the built-in handle or the manual feed. The shredder will then automatically shred the documents into small particles that are difficult to reconstruct.
The HSM Securio B24 also features an automatic start/stop function, which means that it will start shredding as soon as you insert your documents and stop when you are finished. It also has a reverse function that allows you to easily remove any shreds that may be stuck in the shredder.
tip
HELP - MY SHREDDER WILL NOT TURN OFF!
Hello. These automatic shredders are so handy. You put a piece of paper [or two or three] in the paper entry area and it automatically turns on...........how convenient.................BUT eventually, most of us run into the situation where the @#$%^ thing won't automatically turn off..........and then it seems like we either unplug it every time, or start shopping for a replacement.
NO LONGER......Read on.......In most instances, a shredder that continuously runs isn't broken, it merely needs some TLC. Most shredders, contain two tiny sensors near the paper entry area. These sensors are designed to shoot signals back and forth enabling the shredder to turn itself on when paper enters the machine. After the paper has made it through, the sensors then tell the machine to shut off.
Sometimes these sensors can malfunction. This can happen when oil, paper dust, or debris covers the sensors. Covered-up sensors essentially tell the shredder that paper is entering it, thus causing it to continuously run. While this problem can occur in both cross- and strip-cut machines, it tends to happen more often in cross-cut units because those units are oiled more frequently and create more paper dust than strip cut units.
THE FIX: wipe the debris or oil or ink off the sensors. Here's how to do it:
1. Unplug your shredder and look for the sensors in the paper entry area. In the center of the opening, there will be two things that look like marbles - these are what you're looking for. (Please note - if your shredder has a safety flap over the cutting mechanism, you may have to lift it to find the sensors.)
2. After you've found the sensors, use a slightly damp cotton ball or Q-tip to clear away any oil or paper dust. You can use a small pair of needle-nose pliers or tweezers to clear away any large chunks of debris.
If your machine is a model that lacks the electronic sensors - such as a smaller deskside shredder designed for home use - you can still fix the problem on your own because those machines have mechanical sensors. These are also located in the middle of the paper entry and they look like small plastic dividers. (In most of these models, the sensors are white, but they could also be gray or black.) The sensors are depressed when paper enters the machine, which causes it to start shredding. Once the paper is gone, the machine stops.
1. Sometimes bits of paper can weigh down on the sensors, thus causing the machine to run non-stop. But it's easy to clear up this problem by doing the following:
2. Unplug the shredder and locate the sensors.
Remove any debris. Use tweezers or pliers, if necessary, but be careful to not press down too hard on the sensors to avoid damaging them.
Once again, after you remove the debris, plug your machine back in and you should be up and running.
Happy shredding everyone!
PS-60 will not shred automatically-I have to turn on the switch to start and stop
I think the paper feed limit switch may be jammed disabling auto operation. Take precautions to unplug before opening up to inspect for jammed limit switch.
Jammed paper shredder motor stopped won't start
Had this sort of thing happen to me also; sort of. Did you check to see if the shredded paper level alarm has been triggered in the pull-out catch area? Sometimes it forms a pile that trips the alarm before the catch is full. Sounds simple, but check it out. Also check to make sure it's plugged in! I've done that several times, even to the point of calling for help! Did you know the technical help desk always asks if the machine is plugged in first!
1helpful
The shredder will not automatically shut off. After you have finished feeding the documents to be shreeded the machine contunues to run and you must manuall shut it off.
depending on what you have available, either a damp paper towel or alcohol wipe, or compressed air will work to clean the sensor eye located top at the center of the paper feed opening, you should see a little dot wipe, or spray these out well, then turn the machine off and back on again.
built up dust from the paper causes the sensor to keep registering that there is paper coming in hence it won't stop on its own.
Won't turn off once you start shredding, have to manually move to off position
I had the same problem. My husband took it apart & found that there is an infrared signal that is supposed to recognize when there is paper going through & then when it stops going through it is supposed to turn off. The problem was that the infrared signal burned out & therefore the automatic shut-off will no longer work. You will just have to manually shut it off each time.
2helpful
3answers
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Top Shredder Office Equipment & Supplies Experts
NOEL
NOEL
john h
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
