My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
I have no direct experience but you should note no recording will take place unless the signal format is suitable/compatible. HDMI is a digital signal and your VCR/DVD will probably require an analogue signal.
A tv processes the digital into analogue but sockets at the back of tv sets tend to be input only. A minority of tv sets have two scart sockets, the second one usually providing an output sound and video of what is playing on the tv at the time.
I believe it is possible to buy a box that will convert digital to analogue or vice-versa.
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
The TV has nothing to do with it. The medium you use to record with does though as well as the DVD player you use to play the recorded DVD with. Some players will not play DVDR or DVD-RW discs. Check your manual.
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
I have ILO dvd ro5/zu Burner walmart cheapy and I read Capacitors for power supply go bad and leak there are 2 (fuhjyyu 2200uf 10volt) also it runs very very hot so I put in an old computer fan to cool it down works great now, problems with clock flashing and humming noise while recording and playing back. It still has a little hum but other than that it works great 3-4 years old over 150 dvd's burned.
