It keeps turning itself off then turns back on
Hello, I'm Jem, does it have enough clear space around it for heat dispersion? Please check around all its vented areas for possible clogging/suffocation to be sure it's internal cooling fan can cool it appropriately, also check with your hand carefully how hot the unit is..
Hope this is of some assistance, I will try to assist you further if you can comment back. ????
SOURCE: hi, i have a
What is happening is that the "pace" box is forgetting everything that you programmed into it every day.
The reason that happens is because when you shut off the "mains" every night the "pace" loses it's memory. You might check to see if your box has a place to put a battery in it. That battery "back up" would keep the memory intact until the battery expires. It only draws a tiny bit of current but you are correct in assuming that it never really shuts off unless you shut off the "mains"
Zashiban
SOURCE: How can I extend my humax freesat box into another
my suggestion, come out of the box with a splicer cable a small 6 inch piece is enough. Get a high quality cable splitter such of what the Cable guys would use, you can buy them at a hardware store. Note that you can get more than a 2 way splitter however the more you split the lower the quality at the other end,. Anyway you split the cable after your cable splitter 1 to the tv, and take the other one which ever room you want.
Testimonial: "Your explanation is very good,however I must make a final comment when I buy the materials to do the job and see how good the picture is in my conserv"
SOURCE: MY HUMAX FREESAT REMOTE CONTROL DOES NOT WORK WHEN I POINT IT AT THE BOX.
Try removing battery to try to reset it.
SOURCE: how do i retune my Humax freesat box
Find the address and mail it back but it must be in original box
