Canon ZR70MC Mini DV Digital Camcorder Logo
A
Anthony Posted on Oct 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am unable to get any power
I have bought a new ac adapter and still can not get to power up.. Help me please.. Other idea for power up? Reset button or proceedure?
Marvin
Level 3:
Top Expert:
  • Canon Master 85,242 Answers
  • Posted on Oct 01, 2016
Marvin
Canon Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29036132
Points
266281
Is the battery good? A open battery will stop power up even with the AC adapter plugged in.
Dell WYZE 3040 not booting.
Question edited for clarity.
Sounds like the motherboard may have failed. Small form factor computer have always been an issue.
https://www.dell.com/support/kbdoc/en-ca/000126002/wyse-3040-thin-client-unable-to-power-on
https://www.google.com/search?q=Dell+WYZE+3040+not+booting
Toshiba Satellite X200-LC3 no power. i bought new AC adapter but the laptop is not taking juice. no flashing lights. is battery fried that it wont take juice? motherboard issue? please help. This comp
It's either the adapter connection or the MOBO itself.
Anyhow try removing the battery and adapter press and hold the power button for 10 to 20 sec plug the adapter with out the battery and restart. Hope this works if not check the MOBO for jack problem
if battery is already charged try with battery alone. Also be sure adapter is compatible the right voltage IE 19.00, 18.00
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Want power on . When i push the power button to turn on it does nothing.bought new battery and ac adapter.
Remove the battery and ac adapter. Press power button for 10 seconds then connect the ac adapter. Turn on the system. If this didn't work. You need to go to a service center to test your motherboard.
2helpful
My compaq nw8440 does not power on anymore!
When you say "I bought a new power supply", do you mean you bought a new ac adapter?
Try this method and write back to me with the results:
1) Unplug the notebook and REMOVE the battery pack
2) Hold down the power button for 15 seconds
3) PLUG IN the ac adapter to the wall outlet (DO NOT PUT BACK IN THE BATTERY)
After you plugged in you pc, try powering on the unit again.
If it does not power on, please write me back.
Couldn't switch on my laptop;adapter light blinking !
Please take out the battery, and use the AC adapter to boot up only, then put the battery on.
If any abnormal situation occurs, please do a battery calibration as instructed in the manual. Adapter info:
Power problems with AC adapter
Step1 :
Please remove the battery first to verify the AC adapter's problem
Step2 :
Please check the power outlet on the wall by plug another device to the outlet
Step3 :
Please plug the adapter directly to the power outlet on the wall
Step4 :
Please make sure both the wires between the adapter to the wall and to the notebook are well plugged and the LED on the adapter is alight
Step5 :
Please check the power status indicator to make sure whether the notebook is powered on
Step6 :
Please make sure whether the CPU fan perform the testing run when the power is switched on
Step7 :
Please stick into the hardware reset button at the bottom of the machine and reboot
Step8 :
Please remove all of the removable hardware (exp. mouse, PCMCIA card, power adapter, battery, external drives, memory and etc) and install only the necessary components.
Step9 :
Please remove the AC adapter and re-install the battery
Step10 :
Step11 :
If possible, please change another battery to make sure whether it's the battery's problem
Step12 :
1helpful
Monitor not turn on when hooked up to power supply only
Hi...there,
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
5answers
Compaq Presario V2000 no power new dc jack
I think that this can be rated as solved. If it is not solved please let me know.
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
2answers
Compaq EVO N400C PC Notebook Problem brought new battery! fully charged all night! turn laptop on within one second the thing turns off! AC works fine! new battery! old laptop! what can i do, please help?
your laptop should function even without a battery. Remove the battery you just bought and see if only with AC adapter, would your laptop turn on?
If not, then try removing the memory and see using a pencil eraser, clean the contacts of the memory and see if you can power your laptop with only ac
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
