go to your setup menu and shut all timers off...(are you trying to record HBO...this will occur when trying to record any of HBO/Disney) check your manual and make sure you have the right type of disk...+/- makes a big difference
Press the timer button on the remote control. This will bring the manual timer screen up. Use the arrow buttons to select "Cancel". You will now have a list of programmes that are scheduled to be recorded. If any have unresolved next to them, select them and use the arrow buttons to select "Erase". Hope this helps - Pete
This sometimes happens when a disk is not formatted prior to recording .. the DVD is telling you it cant record on it at the time you want because it would have to format first and then start recording so missing the times you have set .
Best thing to do is use re- recordable discs only and format prior to use then the dvd should start straight away .
If not then the set has a serious read problem and requires looking at by a qualified engineer ... Regards Vortash
If you try and record a video with copygaurd it will only record a tiny section. If you press stop or return for 3 seconds you will cancel the recording, try pressing the pause button you edit out adverts, i have not tried this yet but it might work.
