Question about Kohler Electrical Supplies
I have a 7kw Kohler marine generator that shuts of when boat gets up on plane New impeller New fuel filter I started it runs for a while then shuts off It takes a bit to start but runs for 20 plus hrs
  • 2,760 Answers
Well the above logic is good , but I saw something else in your text that makes me think its a fuel delivery problem , you said above "takes a bit to get it restarted" if it was a low flow switch or circuit , it start right back up ! but if its a vapor lock or fuel starvation problem then yep it be a bit tricky to restart it !! (air in fuel) ive seen this happen on mid to large boats (diesel) seems there was a small air leak (crumpled gasket) around there fuel filters and it worked ok till engine heated up to normal temp !! then it lost fuel prime from the day tank and it be difficult to reprime it till engine cooled back down (head scratcher I know all too well) , mfg know this can happen on mobil power units so lots use a small tank (less 3 gal) between the filters and injector pumps it adds a bit of "time" in there if fuel looses its prime for a moment (rolls and swells ) so pwr unit keeps going
Posted on Oct 01, 2016
    Top Expert:
  • Kohler Master
  • 53,745 Answers
I take it that this unit runs the power on board and is permanently fixed in the boat
you mention new impeller so logically that means that it is water cooled drawing the cooling water from outside (underneath the boat)
pursuing logic further if that is the case then there is a shut down circuit for the water flow to prevent overheating should the water inlet become blocked ( weeds, plastic cloth etc)
from your question and statement I would be looking in that area to make sure water flow is not restricted or the protection circuit is operational ( no corrosion in terminals and wires )
SOURCE:
25hp Mariner ,2stroke quite old , starts and runs at low speed beautifully ,once taken up to plane the boat one cylinder tends to cut out, and once boat has slowed down the cylinder comes back to run
Older motors have two jets in the carb. A high and low speed jet. My guess is the high speed jet is clogged, and motor is trying to run on low speed jet.
Mar 06, 2018 | Boating
I have a Kohler Marine 4ES Generator in my 29 Foot Sea Ray and the engine keeps cycling (no load) from almost shut-down to max speed. What can this be? I have changed the Electric Fuel Pump - Fuel...
The governor and / control maybe your issue. Also if you have the electronic governor model, check the speed sensor screwed in near the fly wheel, it should have approx 2VAC on it during crank.
Jun 19, 2013 | Kohler Electrical Supplies
40 MARINER QUITS AT HIGH SPEED WITHOUT WARNING
Check Fuel Pump ,
Check Breather On Tank
Fit New Spark Plugs.
Let Me Know What Happens After That!
Mar 15, 2013 | Boating
I have a Briggs and Stratton 7KW standby generator. I accidentally spilled some oil on it during a hurricane and cleaned it. However, when I try to start it, it will go on for about 15 seconds and then...
sounds more like a fuel problem not oil being spilled on it but check the oil level some have a low oil shut off see if you can keep it running spraying carb cleaner in the air filter that will tell you if it is a fuel problem more so a fuel problem if you left fuel in it for more than 30 days
Aug 14, 2012 | Briggs & Stratton 15,000 Watt Home Standby...
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
Kohler boat genny surges
Check fuel supply, carb etc
Feb 05, 2012 | Kohler Electrical Supplies
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
Jun 13, 2011 | Kohler Electrical Supplies
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
Electrical Supplies Logo
259 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
