Question about Haier Refrigerators
I have a Haier kegerator,just had someone put in freon beer is cold, but the line coming off the compressor that goes up into the cooler part is freezing up
    Top Expert:
  • Haier Master
  • 53,755 Answers
This indicates that liquid is evaporating in the suction line to the compressor
that indicates that the unit has excessive gas and is not working as well as it should
have the gas checked by a professional refrigeration technician
Posted on Sep 30, 2016
6ya staff
SOURCE:
Anonymous
  • 237 Answers
SOURCE: Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Posted on Nov 24, 2006
Jose Ramirez
  • 263 Answers
SOURCE: Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Posted on Jan 01, 2008
Anonymous
SOURCE: Keg freezing!!!!
I have had this product for 2 months and this just started happening to me also.
Posted on Jun 12, 2008
Anonymous
SOURCE: new danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Posted on Feb 18, 2009
Dennis Boxerman
  • 1300 Answers
SOURCE: beverage air dd58 kegerator won't stay cold
the freon system is a sealed system. If you are adding freon, there is a leak. have the leak repaired and this should resolve the issue. Freon should not need filling but one time and only after the leak is located and repaired.
Posted on Jul 11, 2010
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Kegerator no longer running cold
You need a new start device if your compressor is not running/pumping.That is the box on the side of the compressor .If you can put your hand on the compressor to make sure it (compressor) is than you have a Freon leak. The small line copper coming off the compressor should be between 75 & approximately 85 if its not ho you have Freon leak somewhere.
Nov 15, 2013 | Nostalgia Electrics Kegerator Beer Fridge
I have a danby kegerator and temp says 32 but a thermometer i put inside says 46 degrees!!! The beer is all foam and flat. We changed lines and checked the psi and co2.......all is fine. I havent heard...
If its 46 degrees that tells me compressor must be running.So what I would do first is unplug unit,locate compressor condenser coil & fan.Clean condenser coil with brush,air,or coil cleaner.plug back up wait & see.If still not cold enough needs freon.
Jul 27, 2013 | Refrigerators
Have not used the kegerator for several years. Plugged it in and it immediately started getting cold. Then I unplugged it to move it and when I plugged it back in it does not get cold.
Check to see if any of the compressor electrical items came loose when moving.
I had this happen to a customer and he called someone else in who tried to sell him a new compressor.
Apr 30, 2010 | Beverage-Air Kegerator - Beer Keg Cooler...
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
I have an older beer cooler. the fan costantly runs but the refrigeration part of the beer cooler doesn't keep the keg cold? ? ? It's refrigerate is r12 cooled. Do you think I could just re charge the...
You would need to be a certified refrigeration technician to even buy R-12, since it is a CRC refrigerant. The kegerator probably doesn't have service ports so you would either have to braze a low-side port in or use a piercing valve, and fix wherever the refrigerant leaked out from. Basically, by the time you pay a refrigeration tech to do all this, it isn't worth it and you would be better off buying a new one
Jun 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
BEER COOLER ICE PROBLEM
First, dont overstock your beer, good circulation is key. Make sure your condenser coils are clean. Find a happy setting with the help of a thermometer to cool between 35 - 42 degrees. To defrost I put big zipl-loc bags of ice on top of beer. Turn temperature all the way up (the compressor will cut off but the fan will keep running) for a few hours. When the ice is thick i put HOT water in a squirt bottle and spray sections in the ice. Play around with that and see if it works. Hopefully you don't have a bad condenser. Good luck!
Jan 31, 2008 | True TD-95-38-LT Beverage Cooler
Refrigerators Logo
37 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
