SOURCE: How do I get sound on candy crush ipad 2
You sure you want sound? Its the same repetitive 6 second whistling looped over and over. Usually one you start the game you just turn up/down the volume using the buttons. Unless there is an in game mute. Possibly a side switch like on the iphone.
Here's the best information I have found about it. Please calm down and be patient. There are people here with much more urgent problems than your app-addiction. Have fun, anyway!
http://www.crushingcandies.com/candy-crush-saga-level-29
SOURCE: How to delete candy crush from my iPad permanently
Touch the app and hold your finger down until all the apps start to jiggle. You will see a circled "x" in the upper left corner. Tap it to delete an app. When done press the Home button.
You cannot delete any pre-installed iOS app.
If there is No 'X' on any apps you have Downloaded... then check in Restrictions... Settings > General > Restrictions > Deleting Apps = Off / On
If the app is in iTunes, then you delete the app in iTunes (Select the App and Press Delete on your Keyboard). If you then sync with your iDevice, the app will also be deleted from your iDevice.
