The real problem here is not the amount of ac water on the frame but the salt from frozen roads accumulating at this point and not being readily washed away or neutralized
Every vehicle with metal sub frames suffers rust at various points
Yes it is dangerous and if the rust is in the body shell as well as the sub frames , there is no cheap fix
it is best to consider junking it and for that you have a couple of options
you can find a good body shell and sub frame and transferring all of your good gear into it or
if the gear is as worn as the body is rusted , junk it and get a later model car
