Need to replace front tire on pride maxima 3 wheel scooter do I have to replace the whole wheel or can I just replace the tire?
SOURCE: lost the main key and can't find the second key.
most keys for that type of scooter are the same, (not like a house or car key) call Pride 1-800-800-8586 for replacement or any Pride dealer can help you. Also, a paper clip can jump the ignition by placing it in their to get you around temp.
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… [email protected]
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
SOURCE: Replacing the battery on a mobility scooter
hi, ok remove the seat by turning it to the left, there is a lever normally on the right side that will allow it be turned round,
once you done that, lift the seat in a upwards motion, the cover should come away by gemerally lifting it, it should be attached by velco underneath,
you should now see two batteries. 40Ah batteries will allow you to go further if the battery Ah is lower, 50ah batteries again will allow you can go even further NOT faster, if you buy the larger AH batteries please make sure the dimensions of the batteries will fit within the scooter battery holders.
Regards
GeWiz.
Testimonial: "Thanks so much for the help. The seat did come off in the end but with difficulty. Batteries now changed OK. Thanks again. "
