Use a harness adapter if you haven't cut the factory wiring plug in the car. If you have go to www.modifiedlife.com. they have an excellent resource page with wiring diagrams
If you are putting in a after market sterio,you need to go to autozone or walmart and get a sterio plug that plugs into your factory plug and the wiring diagram will be with your new plug that you bought,real easy!!
bluebird, that is JDM car, what country?
a 1990 /94 Nissan toyota bluebird?????
post country, wiring varies by that. and year, make , model and sub models and special radio options offered, in each country.
if a usa car. alldata.com has the answer under wiring ,radio.
read it.
speaker wires you can connect one at a time to see which is which as for the others black is earth, red is usually ignition, yellow is constant power (memory) and sometimes you'll have a blue wire for power out or you can usually just buy an adaptor plug to suit most stereos
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
you will need to get a cord that connects to the sterio and then you need to match them up with these wires
the colors for the radio that are hooked up to the car are
orange is power
red is egnition
blue is power antena
black is ground
other ones will most likely be the sterio wires you just need to find colors that look a like and they will most likely match
DON'T REMOVE FACTRORY CONNECTORS!!!!!!!!!!!!!! Spend $15 and buy a wiring kit. It plugs right into your vechile wires and the kit tells you what wires are what. Splicing the wires will lead to headaces down the road!!!
