Your drain for the inside unit is stopped up and the water condensate that drips off of the coils when the AC is running has no where to go, so it drips off of the collection channel and over flows to the bottom of the air handler, gravity dictates the place where it leaks. You are going to have to unstop the drain.
Yes it is normal for AC to drain on to roof as the drain holes are in base of AC unit. The time to worry is when you don't see it draining on to roof, as this indicates holes may be plugged.
your a/c evaporator drain is stopped up or blocked off can be seen at firewall area on passenger side looks like a short black hose coming out of firewall and turns down with nothing hooked to it if this gets restricted the blackbox under your dash fills with water and eventually leaks in floor you can try and run small piece of wire up hose to unstop but be careful not to punchure evaporator core
Check that the drain pan is completely draining. If the drain is partialy plugged, you may get rusty water from the unit when the water level gets to the support brackets.
