Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
Clumsie Gomez Posted on Sep 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to program a remote controller for a Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television what can I do to make it work.
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on Sep 28, 2016
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14993403
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. .
2helpful
How to Operate a sharp TV without a remote control
HOW DO I GET A REPLACEMENT REMOTE CONTROL FOR SHARP AQUOS LC37GA4X
1helpful
I can't get a remote control to work on it. My
Take your remote to a retail store that sells sharp in your area and see if it works there. If it does then you have an issue with the IR receiver in the set. I would have it looked at by a service company at that point.
The sound goes off intermittently
Forget Sharp's defective speakers. Connect your sound output to powered stereo speakers and disable the internal speakers (look through the TV's menu). The operator's manual explains how to disable the internal speakers. You'll be able to control the sound normally (mute, volume) with a remote control.
I connected my stereo output (2 RCA plugs) to an old boom-box and I get better sound than with Sharp's built-in speakers.
My sharp aquos 37
If it's the LC-37G4U model, double check the System Cable that links the TV to the box. Then, open the front cover of the box; with the TV ON, press the small SYSTEM RESET below the INPUT 3 port.
Let me know if this solution works.
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Sharp AQUOS LC-60C52U
hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Satellite code
What did Sharp tell you when you posted your question to their online support site?
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
