my displays that its charging but when i unplug it it won't turn onmy displays that its charging but when i unplug it it won't turn on
AnonymousDec 25, 2007
I have the same dang problem!!!! Dumb thing won't turn on. Left it charging for hours...I have the same dang problem!!!! Dumb thing won't turn on. Left it charging for hours...
AnonymousJun 21, 2008
****.I love you.Oh wat this is wierd.WEll i pressed re-- whatever it totally worked.****.I love you.Oh wat this is wierd.WEll i pressed re-- whatever it totally worked.
You can't post conmments that contain an email address.
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Let it recharge for a few hours - when an mp3 player won't turn off, use the reset button instead of letting the power drain down. Actually, i take it back - this is the worst most godawful manual I have ever seen - this is the first Mp3 player I have ever seen without a reset button.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Make sure that hold switch hasn't been flipped again. Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
if it is not battery operated, then you have to charge it... what kind of cord did it come with?
if you have a cord that has a usb end then yes you can charge it using your computer.
If it cord has a different end then you need to purchase a charger.
If this is a new mp3 player you should charge it 12 hr.
