During an external call:
1. Press <MENU> and <UP/DOWN> to select INTERCOM.
2. Press <OK> to select the desired handset to intercom with.
3. The external call is put on hold automatically and the called handset
rings.
4. Press <TALK ON> on the called handset to establish an internal call.
5. Press <TALK OFF> on the calling handset or put the calling handset on the charging cradle to end the current call with the external party.
6. The external call is transferred to the called handset.
put ur phone in power off mode and hold vol up and power key at the same time. den phone is on factory mode use reset factory and its take some time pattern lock is open. :-)
To mute the ringer, while in standby mode press the volume-down button to select Off.
To mute the microphone, while talking press the MUTE softkey. To put the phone into do-not-disturb mode, press and hold the do not disturb button on the base.
You can download the manual from the manufacturer's web site at http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU8885om.pdf
there are two cradles available for the 6300, one has two connectors should work when you put the phone in the cradle and switch on the key, the other has one connector and is bluetooth, this requires pairing, you will need to search for bluetooth devices and pair using code 1234. The use of steering wheel controls is not possible with bury car kit. hope this helps. dan
just hold the PS button on the controller and select controller settings and change it to 1, if your talking about another kind of handset just take the controller that is 1 and under controller settings change it to 3 and it should swap 3 for 1 putting the handset to 1.
hold the PS button for 2 seconds if you just tap it in a game it brings up the XMB you have to hold it to get to the settings.
The handset/base keeps a record of who it’s registered to. The base
also keeps a record of how many handsets are registered to it.
Using
the de-register function on the handset deletes the handset from the
base (decrements the count) and deletes the base info from the handset.
All this requires that the base and handset can communicate with each
other.
To remove the base data from a handset when out of range
of the base, press and hold the ‘end’ button and the ‘#’ button
simultaneously until the phone beeps. It will now be de-registered from
the base.
However, the base will still have this handset in it’s record.
To
de-register all handsets from the base, remove power and the base
handset. Press and hold the ‘flash/find hs’ button while applying
power. Wait for the beep and release the button. The charge light will
now flash. Sit any handset in the cradle. When the flashing stops, all
handsets are inhibited from connecting.
However, the handset
still appears to be connected to the base unit. Pressing talk will give
an ‘Unable to connect’ message. To re-register the handsets to the
base, you have to de-register the handset first with the two button
method.
Of interest, pressing ‘*’ and ‘#’ on the handset while
reconnecting the battery is suppose to reset the handset. Doing the
same on the base unit puts you in some sort of diagnostic mode. Press
speaker to exit.
With the H700 BT headsets the pairing mode is different
from other BT headsets. to put it in pairing mode you first hold the
talk button on the headset until the purple light comes on.Right after
the purple light comes on you have to flip open the headset for it to
stay in pairing mode. From there you continue through the phone. It
will ask for a password; that will be "0000". then connect. This headset can sync with laptop.
