SOURCE: bose wave radio signal fades in and out, cd stops and starts
i would check the power supply for bad solder joints or cracks in the traces on the printed circuit board, possible around the heaviest components (usually a transformer) or a loose connector.You can use the eraser end of a pencil to push on components to see if any of them cause the problem to manifest, and if so, turn off the power and reheat the solder connections to that component.
SOURCE: CD player
Not much of a answer but there are plugs that you can hitch a exterior cd player to it
and well you still will have that great Bose sound...yeah!
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
SOURCE: I have a bose acoustic wave,single disc model
Had the same problem. Mine the cd drive got out of alignment. Sorry to say the fix is to have it replaced. BOSE will do this for about $150. Typically this includes the one year service agreement, a full system "tune up" and a one year warrenty.
Call BOSE and they will take care of you.
SOURCE: My Bose Wave radio/cd won`t play cd`s anymore. The
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
