My Canon PowerShot A1100 will not turn on. I have put in new batteries, but will not turn on.
That happens to mine also and what ? did i plug in it's own electrical charger in and out for a few times of course plugged to the wall outlet.and that fixed mine it does it once in a while and ? fix it this way i hope it works for you too it works like flashing your camera.good luck.
Testimonial: "Mine does not have it's own electrical charger."
I dropped my camera recently and I've tried various times to turn it on but it refuses to do so. - Canon ... If the battery cover does not press down on the switch the camera won't go on.
If you searching tech support Tollfree number regarding with Dell printer, Call Canon printer customer service phone number +1-877-778-8.9.6.9 and get instant solution. Get more information visit us: http://printertechnicalhelp.com/canon-printer-technicalhelp.html
Testimonial: "The battery cover does press down. Just won't turn on."
Hi Charlie,
Please provide additional info if you really want help in this site. Questions with sufficient information do get answered sooner than others so consider that. Otherwise, check answers to previous questions of similar nature and you might locate a suitable solution for your question.
Testimonial: "what else can I say? I push the button and it won't turn on. I have rechargeable batteries in it and have made sure they are charged. I have looked into where they go & looks OK, nice and shiny contacts, I don't know what else I can say. I called Canon about it and they no longer repair this camera. I have looked for a replacement, but none of the small camera's have a viewfinder and I cannot see what I want to photograph without one. So I am just out of luck."
SOURCE: powershot s3 is
clean off all fo your contacts on the inside and the battery door, even try puling up on the connectors so that they get a good connection
SOURCE: my canon powershot A550 camera behaves as low battery with new b
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
SOURCE: why does my camera not work with new batteries
Voila fixed.
SOURCE: My Canon PowerShot A570 IS won't turn on. I put
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
SOURCE: Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
What else can I say? I push the on button and nothing happens. I use re-chargeable batteries and made sure they were charged, even put in another set, just to be sure they were good. Looking into where the batteries go, looks OK. I called Canon & they say they no longer repair this camera. I can't find a replacement camera this size with a view finder and I can't see what I want to take a picture of without it when in full sun. So, I am just out of luck.
