Found this by google: Symphonic DVD/CD player Model WF-104 worked with Comcast Cable remote with code 0675 - If this doesn't help post the Model name too.
The real problem with the Comcast remote is that there is no other
brand, it's not like a Sony remote that's relabeled or anything.
Fortunately, Google helps again, and it turns out Comcast has a page
online about programming the Comcast remote control.
Comcast 3-in-1 remote control
To program the remote to work with your Sony TV, you need to take the
following steps:
Find the code or codes for your TV from Comcast's list [PDF]
Turn your TV on
On
the remote, press and release the TV key on the very top of the
remote.
Press and hold the Setup key, until the "TV" key
flashes twice, then release the "Setup" key.
Using the number
pad, enter in the first 4-digit code found next to your television brand
on the chart. If you do this correctly the "TV" key will flash twice.
Now it's programmed!
Now point the remote at your TV and press
the Power key. If the TV turns off, you're golden. If not, try
again with the next code on the list.
You should try codes for Funai, Symphonic, & Sylvania. Some Tecknikas are same as some of those. At least in my Comcast cable box remote code listings.
The remotes you get from the cable company are universal and kinda cheap. ive ran across this multiple times but since i dont know what model remote you have the only advice i can give is that the code you used is not the right code if it doesnt do all basic functions (on,off for the tv,volume)its just the wrong code if the codes you stated are the only ones available the book you got with the remote should explain how to run an auto scan.hope i was some help
