I have recorded 3 CDs,each with the same result! Both the CD and CD-R sides of the unit play back recorded CDs perfectly.The blank CD-Rs are"new" old stock.Could this be the problem, or is it the unit?? THANKS
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
The recorder is writing TOC data to the disc's PMA (Program Memory Area). Never turn off the power while this display is
showing.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
