2006 volvo s60
SOURCE: volvo s60 abs systems
it is most likely that the abs module is faulty,, if the fault codes are read and it shows a fault with the right rear sensor then the module is faulty,,they usually go wrong at about 110//140k
SOURCE: engine codes P0101 and P0170
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
Air flow sensor problem, maybe causing the second code to go off.
The air flow sensor should be right near your air filter box.
P0170 Fuel Trim Malfunction (Bank 1) Oxygen Sensor
SOURCE: volvo s60 idle sensor
if you could get your hands on a scanner to read some live data it would help your plight,there is a cam position sensor when you take of the the plastic head cover at the timing belt end,did you check plugs,it also might help to clean the maf with some contact spray,sounds like plugs
SOURCE: how do I reset the maintanance light on my 2008 volvo s60? NOT th
a shop has to do it. or you need toplug it in to the computer and have a program.
SOURCE: CODE 042 ON A VOLVO S60
Brake lights and cruise control are not set properly.
Easy check - are your brake lights coming on with just the usual light touch of the pedal? If not, then the microswitch that senses that your foot is on the brake needs to be adjusted or replaced.
