Acer Aspire 9300-5349 Notebook Logo
Certain keys no working...Like the T and - Acer Aspire 9300-5349 Notebook
How to code a new key to a toyota 2004 model
key codes are dealer issued --if you have a good working key their are some locksmiths and a few stores [some larger named hardware,home stores ] can cut certain electronic keys the following links show how to do programming on certain 04 toyota s but its even specified in links that it doesnt work all the time
2004 Toyota Sienna LE Immobilizer Key Programming How To Toyota Ignition Key Programming
CERTAIN KEYS NOT WORKING ?
Usually its a bad keyboard that needs to be replaced but you can
try to disassemble it and reconnect it this may help.
Regards
Certain keys on my hp pavilion don't work
Blow the keyboad with air blower. try to reinstall all drivers and if not. you have to attached external keyboad temporarily while fixing the issue.
What must I do to get the calculator on my keyboard to work I have a Dell inspiron 1750 laptop and Viste Home edition software
Get latest Vista driver for your keyboard/laptop. The calc is just a mapped key on the keyboard that runs the macro "calc" in the command line. and you may be able to use 3d party key mapping software to reassociate certain keys to do certain macro commands.
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
2helpful
2answers
I have a Dell Inspiron laptop, and certain letter
This could be a possible hardware issue. You can try to use an external USB keyboard and check if the keys are working or not. If you do not have an external keyboard, you can try to use the onscreen keyboard. To do this, go to start>programs>accessories> accessiblity and then choose on-screen keyboard. Open a notepad and try to use the keys which are not working using the onscreen keyboard. If onscreen keyboard works fine , then you need to get the keyboard replaced.
2answers
Toshiba Satellite L3505D-S5938 Intermittant Keyboard Issue
Hi, This is beacuse of Virus/trojan that blocks the function o certain keys,
Try scanning your system with good antivirus, this would solve your problem permanently
RATE THIS SOLUTION
RNJ VINOD KUMAR
Certain keys won't function on keyboard
Could be that the connector from the keyboard to the mainboard is crooked. Try taking the keyboard off and wiggling the connector from the keyboard to the board so that it is a snugger fit.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
