There is a procedure for adjusting the treadmill belt. Almost all the treadmill follows the same procedure. If you wish to know how to adjust the treadmill belt properly then check the below added link. Even after that if you face the same problem then you have replace the running belt of your treadmill.
http://electro-medical.blogspot.com/
Check page 27 in the owner's manual:
"If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD. Using
the allen wrench, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each side of the walking
belt 3 to 4 inches off the walking platform. Be
careful to keep the walking belt centered. Plug in the
power cord, insert the key, and carefully walk on the
treadmill for a few minutes. Repeat until the walking
belt is properly tightened."
