My mother in law gave me her machine but I am having trouble setting stitch lengths - straight stitches are very small and not 100% straight - I seem to have got the tension right between bobbin and needle now but stitch size selector isn't making much difference - I also need to get the sizes and width of Zig Zag stitches set correctly on this machine there are 1-26 stitch options but so far I can only get straight and zig zag to run anywhere near correctly HELP !!!
SOURCE: The machine is not stitching
If the bobbin thread is coming up to the top, then the thread is not under tension correctly. I think that this is a top loading bobbin so the bobbin will go into the bobbin holder, then you pull the thread back and press it into a tension device - should hear it click into tension. Now pull the thread back towards you and it should not come out of the tension. The bobbin should turn anticlockwise as the thread is pulled from it.
These bobbin holders usually will have a small adjustment dial on them and it should have the standard setting marked in red. It is very unusual that you would need to change this but check that it hasn't been messed with perhaps. If you have the machine manual check where they say the dial should be set. More likely that the thread is just not into tension fully or at all.
The manual may give you other troubleshooting tips too.
A good resouce is www.sewing.about.com for general machine tips, cleaning and threading issues.
Hope this helps.
SOURCE: how do you set the zig zag stitch on a Jones
I have been gifted a Jones ym260g. Does it do straight stitch and if so, how?
Hi
Please check the manual for your sewing machine:-
Also check the links bellow:-
http://www.ehow.com/how_15056_stitch-length-setting.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
