Subwoofer repaired once because its switching power supply goes bad, after repairing this problem occurred.
SOURCE: My Polk PSW 303 subwoofer emits a hum when plugged
Hiya sounds alot like there is a power supply issue with the unit that will require repair for it to be doing off or on. Probably wont be to expensive, request a quote first to make sure viable.
Best of luck
SOURCE: Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
SOURCE: I have a Sony Suround sound rec. mdl # STR-DE675
The Left Line in, usually or get an RCA Y-cable adapter and share it between the two inputs.
