My Bosch Vision 500 Washer is always giving me error codes E17 and E13 E17 indicates that water is leaking and getting into the bottom of your machine E13 indicates that your pump...
Inspect the tube for obstructions as it may cause the dishwasher/washing machine to overfill with water. Remove any gunk and run a test wash.
If the problem still persists, check the float and switch are operating correctly and replace the float switch if required to solve your worries.
E17 is
Machine goes out of balance or vibrates excessively when
spinning.
Make the machine level
Adjust feet to touch the floor
Redistribute clothes evenly.
E22 is residual water in sump, this could be blocked pump, dirty filter, grease build up. If you have removed white pump cover to check for blockages, ensure that it is completely clipped back into position before trying again. The non return valve maybe allowing dirty water to drain back into the machine. If you tend to run a quick wash a lot, you may need to boil a kettle and pour it into the sump to clear any build up from around the optical sensor in the sump. Post if you need further assistance
When the washer shows error code E17 you need to turn the tap fully on and check that the supply hose is not bent or jammed up, next make sure the filter is clean. Then make sure the water pressure is not too low. After you do all that, run a load with no clothes in the washer and use one cup of white vinegar and the code will dissappear
F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter. Also check water pressure is not too low If all these test ok you need to run a load with no clothes with 1 cup of white vinegar this will solve your issue.
