Question about Water Sport
Waverunnner vx110 rear bucket will not come down have a code 157
2008 Yamaha VX110 Deluxe will not go past 35 MPH in the water it's like it's restricted
A f
Few things to check would be >>>make sure the intake grate for the pump is clean and then remove the hood and make sure you are getting full throttle response bye checking the throttle linkage.
Dec 11, 2016 | Yamaha 2006 WaveRunner VX110 Deluxe
2006 yamaha waverunner FXHO will not accelerate above 15mph
vx110 , are all cylinders working ?? could be plugs, injecters, or worse the valves aresticking open ! pressure drop test by dealer !! compression test also ! clean fuel ??
Jul 07, 2013 | Yamaha 2006 WaveRunner VX110 Deluxe
Code 157
Error code 157 on your vehicle indicates a problem with your mass airflow sensor. The mass airflow sensor gives a reading based on the air intake and output within the engine compartment. A properly functioning sensor will contribute to better fuel economy. In some instances, you may be able to clean your mass airflow sensor to clear the error code, but the error will most likely return in a short time. Fortunately, replacing the mass airflow sensor is a reasonably simple repair.
Read more: How to Correct Engine Code 157 ' eHow.com http://www.ehow.com/how_7982654_correct-engine-code-157.html#ixzz2IH5Ki64X
Jan 17, 2013 | Ford Windstar Cars & Trucks
1993 Ford Tauras engine light comes on intermdently @ 45 mph then goes off . What to do for smogging?
that is the code for your down stream o2 sensor . you need to replace that
Nov 12, 2012 | 1993 Ford Taurus
I have a brand new LD651EBL. Picked it up this morning. Just plugged it in. Keep getting the CH 24 code. The bucket is all the way in. Is there a fix or do I need to return it?
There may be some packing material left in the bucket or tape that is holding the float valve in place. In which case, the float valve may be in the UP position, which tells the unit, that the bucket is full.
Check the top of the bucket for the float valve and make sure it's in the DOWN position. Reinstall the bucket 'squarely" in the bucket holder and making contact with the bucket safety removal switch on the rear wall of the bucket holder.
If this continues to happen, consult the Troubleshooting Guide in the Owner's Manual.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | LG LHD65EBL Dehumidifier
Bucket full light blinking, code 01
Assuming you have already emptied the bucket (?), the bucket may not have been reinstalled properly. When this happens, you get what you described. Turn the unit OFF & unplug it. Remove the water collection bucket an reinstall it, so the it fits "squarely" into the bucket holder from top to bottom. It needs to make firm contact with the bucket removal safety switch on the left rear wall of the bucket holder. The bucket should not tilt down at the bottom when installed properly. Plug the cord back in and turn the unit ON. Set the humidity extraction level to 35%. If installed properly, the unit should turn ON within 5 seconds.
If the above does not solve the problem, the bucket safety removal switch may be broken. Remove the bucket and try activating it with your finger while the bucket is removed. If the unit doesn't start within a fem seconds, the switch is bad and should be replaced.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | LG LD65EL Dehumidifier
Hello , My Kennmore Dishwasher is not draining. I cannot find where the drain area is to see if there is a blockage. The model number is 665 157 72990 ( the numbers are worn off a bit and may not be...
GO UNDER YOUR SINK FIND THE DRAIN HOSE COMING FROM THE CABINET IT WILL EITHER BE OFF WHITE OR BLACK FOLLOW IT TO THE DRAIN POINT EITHER AIR GAP DISPOSAL OR SEPERATE DRAIN TAKE OFF CLAMP GET A BUCKET AND RUN D/W SEE IF IT DRAINS INTO THE BUCKET THEN YOU KNOW WEATHER IT IS A D/W PROBLEM OR A DRAIN SINK ISSUE. MOST D/W HAVE A CANCEL / DRAIN BUTTON WITH HOSE IN BUCKET HIT THE CANCEL BUTTON IF WATER COMES OUT YOU KNOW YOU HAVE A SINK PROBLEM MAKE SURE YOU HAVE AT LEAST 1 GALLON OF WATER IN THE D/W TO DRAIN IN TO THE BUCKET
Jul 21, 2009 | Dishwashers
Water Sport Logo
2,376 people viewed this question
Top Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
